Kali40sxer »
https://forums.nicoclub.com/kali40sxer-u3636.html
Sun Dec 15, 2002 10:13 pm
Recently, I installed AEM short ram.After the installation, I had problem with startingEverything seems fine when I turn my key to ON position (Signal lights, headlight, stereo all fine)But all power cut once I turned the key to racking positionNothing happen (No cranking) but one loud "click" sound from engine compartment. (might be a relay)
Can anyone give me some advices?? Thanks in advance.
At first, I thought something wrong with the alarm start killer. But it would start even if I took away the alarm by removing the "brain" unit and reconnect the ignition starter wire.I tested the ECU, the code is 55 indicated all normal. (I learned it from FAQ. Thanks for everyone that put the FAQ together) I tried to look thru all the connection around the intake like plugs and clamps.
Should I tow it to dealer?? :help
