R. wrote:get a resistor and make it normal
PoorManQ45 wrote:No, a resistor will simply waste power.
Not using a resistor might cause the LED to burn out faster. Depends what voltage the LEDs were built to work off of.Dittoz7 wrote:Wouldn't that just burn the LED off faster?
That's the stupidest thing I've ever heard. Waste power?PoorManQ45 wrote:No, a resistor will simply waste power.
Dattebayo wrote:Look at the old bulb and figure out how much power the old bulb used and use ohms law to figure out what size resistor you need and solder it in parallel with the LEDs.
That's the stupidest thing I've ever heard. Waste power?PoorManQ45 wrote:No, a resistor will simply waste power.Cars have an alternator, you dork.
The resistance does indeed need to be there for standard flashers to work properly, but adding a resistor is not the way to do this.poems2beats wrote:PoorManQ45 wrote:No, a resistor will simply waste power.
Waste power? More like add resistance that needs to be there.
LED lights have much less resistance that a regular light. Thus they draw more amps. The higher amp draw is what causes the "flasher" to quickly go on and off....
That's the stupidest thing I've ever heard. In parallel?Dattebayo wrote:Look at the old bulb and figure out how much power the old bulb used and use ohms law to figure out what size resistor you need and solder it in parallel with the LEDs.
Dattebayo wrote:Hey, I screwed up by saying parallel when I meant series. You have no excuse.
Also, I failed to mention that using a lower voltage LED and a different schematic layout might be required.
Kinda like this thread now. Thanks.PoorManQ45 wrote:It's small, but it is wasted.
I actually gave the proper answer. You guys are giving ghetto answers...Dattebayo wrote:Kinda like this thread now. Thanks.PoorManQ45 wrote:It's small, but it is wasted.
Thank you Bean!Beancooker wrote:http://www.v-leds.com/Electronic-LED-Fl ... 22487-1-3/
They have what you need. I used one for my LED turn signals. They blink at normal speed.
Resistors are the dumbest idea I have heard. LED tail lights and turn signals already have the proper resistors installed to reduce the voltage from 12v to 3v. Adding another resistor will just cause the lights to fail (not light up).
Buy the damned $17 flasher and do it right.
yep if a job is worth doing, its worth doing right.Beancooker wrote:http://www.v-leds.com/Electronic-LED-Fl ... 22487-1-3/
OMG, someone from NICO who actually knows who Tim is and what he is capable of. At least half of the guys from my Subie meet have a Tim tune, and the other half all seem to be saving for it. Since his shop is 100 miles away, and he also tunes out of PIA in Tacoma (20 miles) everyone up here is running his tunes.Zydeco wrote:
PS. beancooker im totally jealous that you have a Tim Bailey tune.
Beancooker wrote:OMG, someone from NICO who actually knows who Tim is and what he is capable of. At least half of the guys from my Subie meet have a Tim tune, and the other half all seem to be saving for it. Since his shop is 100 miles away, and he also tunes out of PIA in Tacoma (20 miles) everyone up here is running his tunes.Zydeco wrote:
The man can extract gobs of power and do it reliably and very safely.
Thanks for the compliment.
There isn't an improper way to do this if everything works as it should. Chances are a simple electronic flasher is comprised of a fairly simple circuit that is isolated from the light circuit by using an internal relay. As such it likely has some resistors in it as well. Given the waste heat is neglible for this type of application there really isnt a need to make an issue of it. It is however much simpler to use an electronic flashing module than figuring how to set up the LED circuit to have the proper resistance while maintaining the voltage one wants/needs at the LED.PoorManQ45 wrote:The resistance does indeed need to be there for standard flashers to work properly, but adding a resistor is not the way to do this.
A resistor will convert some of the electricity into pure heat. It is a waste.
The proper thing to do is to use an electronic flasher that is not dependent on resistance.
