rap on S13 KA24E auto transmissions
Kaferwerks
Car: 74 VW Beetle 89 240sx xe
so whats the reputation of them?
seems like the shift from 1st to 2nd on my '89 is somewhat of a jerk.
ive test driven other single cam S13s and some twin cams, seems like the singles shifted this way as well, but not the twins.
is this a 'normal' thing? or is it a possible problem? any way to correct it?
Kaferwerks
bump
i2ice4m3
Car: COUNTERSTRIKE!
have you tried changing the transmission fluid?
Kaferwerks
i2ice4m3 wrote:have you tried changing the transmission fluid?
i havent but the fluid is not low and is clean as a whistle.
180fan
Car: 89 fastback
yeah but it's probably old and is varnishing over
onosqv
Car: '92 240sx Vert
the twins will shift that way once they get to be 17 years old...
It all depends on how the transmission was treated and maintained. Most 240 auto transmission's weren't very well maintained.
It's normal... 17 year old transmission, what do you expect?
Kaferwerks
brokeAs240sx wrote:the twins will shift that way once they get to be 17 years old...
the transmission, like the rest of the car, was/is treated like royalty. car only had 57k og miles when i picked it up and is just now creeping up on 69k.the car only saw 1200 miles of use in its last year with the PO
Kaferwerks
bump
180fan
Car: 89 fastback
~70k don't mean a thing, especially on a car that's as old as some members on this board. Stuff still ages, oxidizes, electronics go bad, etc. Check to make sure that the resistor up in the front of the engine bay is connected. Some folks still seem to believe that "rougher" means "faster" and pull that resistor up front to make the transmission dump into gear. Either that or the resistor could have gone bad too.
Acecool
Car: 1989 Nissan 240SX Hatch Pig KA24E 126k
Mine used to shift rough, but then I drove it rough for a while, now it shifts smooth.
Kaferwerks
where is the resistor located? any way to test it?
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
Kaferwerks wrote:seems like the shift from 1st to 2nd on my '89 is somewhat of a jerk.
The 1st to 2nd shift is very firm; it's normal. My 91 240sx also has the 'jerky' 1st to 2nd shift; it's been that way since it was new and now after 160,000 mi, it still does it.
If the dropping resistor was disconnected, there would be extremely hard shifting and the shifts would occur at much higher RPMs.
