How much did they charge you for this outstanding piece of work?Sentientbydesign wrote:Those of you who live in SoCal know that we are in a constant state of road construction.
There are 3 projects going on on my 7 mile commute to work. I recently had a couple of encounters with pot-holes and my alignment was off so I got up early this morning and took my car in to the tire shop that I have an alignment policy with.
I give them the keys and wait. When they're done and I get my alignment measurement sheet back, I'm appalled. Not only is the paper barely legible (printer out of ink), but my rear Toe is still way out of spec; 3/16" when the max is 3/32. I take the paper back in and the desk guy tells me... "Oh, it's only about this much (making a small gap between his fingers)..."
I tell him it's still out of spec and he looks again and realizes that not only is the left rear toe out of spec, but so is the rear thrust angle (a result of the left rear). So I WAS going to be on time to work, but no longer. Got to work 45 mins late because of their mess up.
Final numbers weren't perfect, but were much better.
Front-
Right Toe- 0"Left Toe- 1/32"
Rear-
Right Toe- 1/16"Left Toe- 1/32"
Camber is still a little high at -1 to -1.5 degrees on all four wheels, but I suspect the sports suspension to have something to do with that.
I'm picky about my suspension specs. If I had the time and they weren't so busy, I'd have made them adjust a few things, but meh. At least the car goes straight now and doesn't "dance" on uneven roads.joe603 wrote:good on you for noticing before you left!
I have a policy with Discount Tire/Evans Tire. Just under $200 yields me a lifetime alignment policy. I can go in daily if I wanted. Only stipulation is that I can't do my own suspension worktelcoman wrote:
How much does the dealer charge?
Telcoman
Please elaborate as I'm not following your train of thought.SteveTheTech wrote:Hey Nate,
Take a look under the rear of your car and if you can snap a pic of the eccentric lobe postitions. It's highly likely that your adjustements are maxed out and it cannot be brought back to spec, without out component replacement.
This is a prime example of what you get with your "lifetime" alignement which I have always felt is a scam. You get what you pay for.
Ahh worktime multitasking fail.Sentientbydesign wrote:Are you suggesting that some suspension parts may be bent or damaged and therefore the alignment cannot be put back to specs without replacing those parts?
And the "scam" portion was just your rant against cheap mechanics performing shody jobs?
