Range: Looses 1.5 miles for every accual mile driven ECO and no AC
The web's first forum dedicated to Nissan's groundbreaking electric car, the Nissan Leaf.
Solarman
Car: 2012 Nissan Leaf
I recently purchased a 2012 Leaf with only 4,500 miles on it. Just like new. Dealerships propose that it's range is 85 miles if ECO mode on and no AC or Heat, very soft on the pedal, rural speeds like 35-45 mph, on flat terrain (optimum conditions). I have been driving like this to log true results. The range gauge looses miles 1.5 miles to 2 miles for every actual mile driven (as shown on the trip odometer). Every day continuously.
I took it to one Nissan dealership. They ran diagnostics and checked battery. All test good. They recommended I call corp Leaf specialist. I did. He asked questions, and concluded something is wrong, suggested taking to another dealership for testing. I did. Same tests, same results. They suggested the district Leaf specialist to meet with me. The district specialist after hearing test results, and even knowing that I drive ONLY in ECO mode, No AC or Heat, flat terrain (the California Delta ! ) using rural speeds of 35 to 45 mph and in small towns, on 70 degree days, with only me in the car and a light foot - the corp specialist said "THE CAR IS PERFORMING AS DESIGNED". NISSAN HAS SPOKEN.
I get no more than 50 - 60 miles on a full charge. And Nissan gave me no avenue for a resolution for this. Nissan declares that this is the way my leaf "is designed" to perform. I am stuck. And for those of you who will ask, yes the tires are gently over-inflated for an optimum tread surface on the road - by a Nissan dealership and my own visual inspection. How are we do get the involvement of Nissan management when their specialists use the standard textbook disclaimer "The car is performing as designed?. Solarman.
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Welcome to NICO! I think you might find this article of interest:
Independent Tests Show Nissan Leaf Electric Cars Lost Range In Hot Climates
Have Nissan Leafs in hot states suffered premature battery aging, or is the apparent loss in capacity down to a malfunction in the Leaf’s dashboard display?
That’s been the question on the lips of Nissan Leaf owners worldwide after some owners in Phoenix, Arizona, began reporting that their cars had lost capacity bars.
Earlier this month, Andy Palmer, executive vice president of Nissan reportedly dismissed reports of early battery capacity loss as a faulty battery level display, but now an independent investigation, led by Leaf enthusiasts, has concluded that Leafs with lost dashboard capacity bars do indeed have a smaller range than when they were new.
The test, organized by Leaf owner and electric car advocate Tony Williams, took place over the past weekend in Phoenix, Arizona.
Using twelve different Nissan Leafs with varying amounts of battery capacity bar loss, Williams and his team of volunteers meticulously recorded each car’s state of charge versus distance travelled on a pre-planned route, using the popular third-party GID state of charge meter for added accuracy.
In order to eliminate as much noise from the data as possible, each driver was given a set of strict test conditions to follow, including no use of air conditioning, and traveling at a pre-set speed where possible.
Since the test ended on Saturday, Williams has been carefully collating the data from the test.
The results show a clear loss of range in line with indicated battery capacity loss.
Moreover, some of the Leafs used in the test exhibited battery capacity loss after two years far greater than Nissan's own five and ten year battery capacity estimates predicted.
For Leafs with 11 capacity bars showing instead of the full 12 capacity bars, indicating approximately 15 percent loss in battery capacity since new, ranges of between 73 and 80 miles were recorded, in keeping with the EPA’s official range estimate for the car.
For the six Leafs with 10 capacity bars showing, an average range from full to empty was recorded of just under 72 miles per charge.
The worst affected Leaf, with four capacity bars missing, or around 60-65 percent of its original battery capacity remaining, was only capable of driving 59 miles before running out of charge.
Those Leafs examined with lost capacity weren’t all older, 2011 models either.
“One woman, who just bought the car a month ago, couldn’t come close to 100 percent capacity,” Williams said. “When fully charged, her car was in reality only holding 91 percent of its original ‘new’ capacity.”
Speaking to Williams earlier on, we were told that despite some extensive searching, the team could not find a single Nissan Leaf in Phoenix which had its original battery capacity intact.
And that included brand new 2012 Leafs sitting on dealer lots.
The test results certainly vindicate those with lost capacity bars who had insisted their cars were suffering from premature battery aging, but without intervention from Nissan, it will do nothing to calm the fears of Leaf owners in hot climates who have yet to experience any battery capacity loss.
At the time of writing, Nissan has not formally commented on this test.
http://www.greencarreports.com/news/107 ... t-climates
ronin47
Car: 1995 300Z
I know next to nothing about the Leaf, but I overheard a conversation about the 2016 getting a better battery to fix past issues. Again, I know nothing about electric cars, so I could have misunderstood, but if that is the case, maybe that is why you got that response from Nissan?
Stryker One
Car: 2013 Nissan Leaf SL - Black
I have found that I get better range with that stupid "ECO" function turned off.
Return to “Leaf Forum”
