Randy's RB20 Hatch Build 2.0
DriftX
Car: '89 240sx
Picked up a stock auto 89 hatch.. Zero Rust, straight body, fair paint, never been wrecked.
Plans:
RB20det swapNew clutch, Timing belt, accessory belts, thermostat etcFMICFull exhaust550cc Injectors14psi on stock turboCarl H Rom TuneCarl H Harness Conversion
Down the Road:Tanabe Sustec Pro CoilsRUCAs, Toe Rods, CC platesFull 5 lug with Q45 Brakes, s14 brakes rearFresh PaintS14/GTR Seats
Day one.. gutted engine bay all the way down ready for a fresh coat of the factory gray paint
Day two.. Drilled holes for clutch slave.. tore out all the auto shifter and anything associated with the 5 speed swap
Car goes to paint shop thursday (hopefully no snow lol) and sprayed Saturday morning. Hopefully we can drop motor in Sunday, if not next thursday
Cheers
Modified by DriftX at 9:03 PM 2/23/2010
Modified by DriftX at 11:18 AM 3/1/2010
DriftX
Car: '89 240sx
Ordered:
Walbro 255 Fuel PumpMishimoto Radiator2 12in Electric fansClutch SlaveStainless Clutch lineNew Soft lineClutch Master cylBrake master cyl
Need to get:Heater hoses and 90deg elbowsFew vac linesOil Drain line
danielmcn
sweeeeet!! I just picked up a 90 coupe and I am doing a rb20det swap too. good luck
DriftX
Car: '89 240sx
Picked up a brand new Corbeau seat for 200 bucks, should be nice to keep my fat a** planted rather than my worn to piss stocker
DriftX
Car: '89 240sx
Got the car back from the paint shop. Had the engine bay stripped, frame rails coated with rock guard and engine bay painted base clear of oem gray paint, looks sick.
danielmcn
DriftX wrote:Got the car back from the paint shop. Had the engine bay stripped, frame rails coated with rock guard and engine bay painted base clear of oem gray paint, looks sick.
TAKE SOME PICS OF IT.... please.
DriftX
Car: '89 240sx
Paint..
DriftX
Car: '89 240sx
Got a 14in fan and some wiring...Ordered:J30 Front calipers, no oem rotors and padsConversion hubs front and rear with my awesome discount couponR32 4.30 VLSD and AxlesS14 rear rotors for 5 lugR32 GTR wheels (thanks carl )
As soon as I get my harness back (sunday-ish?) I'll be able to fire the car up and drive it.
Once the car is up and running well, get the five lug done then some Tanabe Sustec Pro coilovers.
supersayianjim
Car: 89 240sx(s13)
looks really good(carl h does an excellent job)!!
DriftX
Car: '89 240sx
Thanks!
Got my harness from Carl today, put it in and got it started tonight
Sil240
Car: Nissan S13 "The One Cam Wonder"
NICE!!!! looks really goodCongrats!!!
You should of went for the 1 sided IC.It would of cut down on your IC piping a lot.But it looks good either way.
Why don't you see if you could wrap your cold pipe or make a heat shield, so that the hot air off the Rad and Exhaust manifold can't get to it.
