Random where does this go?
snowyred180
Car: 1994 Nissan 300zx TT, 1995 Acura Integra GS-R, 1994 Honda Prelude
I'm building a 91 shell with a KA24DE... need to know where a few things go/bolt up/plug in...
Where does the A/C fan plug in the wiring harness? I've looked like 100 times and still can find where that plugs into. A/C fan goes to nothing right now... it's just hanging down.
Where does the fan shroud bolt up to the radiator? I've got the top two holes zip tied at the moment, but I have no idea where the shroud attaches at the four holes at each corner of the shroud.
Last, there's an orange breather tube next to the manual transmission (pass side, speed sensor area). It looks like an electrical wire. It's supposed to mount up to the transmission somewhere. Mine's hanging down on the ground now :(
Any help would be greatly appreciated. If not, I'll have to find one in the junk yard. There's not too many DOHC S13's around here though, otherwise I'd just go and call it a day. Thanks.
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
Yes its a breather hose and it has a bracket that the top trans bolt goes into to hold it up and not get clogged and keep it breathing so to speak.
Um if the shroud is zip tied and not moving, then just do that. How easy are zipties to replace.
Should be in this pic.
pic of the A/C plug.
*tap*tap*tap* "Enhance"
snowyred180
Thanks for where the breather goes! I think the DOHC wiring is different for the a/c though. Mine doesn't have that plug? I'll double check. I have yet to take it on the road yet, so I'm not sure if zip ties are going to hold that shroud in place. Thank you so much fr the pictures! Now I know where to start looking! Anyone else with DOHC wiring+ OE fan?
breadbox
89 Koop
84 720 4x4KC
on my rad, there are holes top and bottom, If you are still running a stock rad it should be straight ziptying to those.
Hijacker
Car: '92 240sx Convertible
'94 F-150
91+ S13s are different in their A/C plugs than 89-90s. There should be a plug near the fusebox/battery tray area that the fan plugs into. You can always grab an FSM and go over the plug placement in the EL section.
