random start troubles
pathfinder_se_black
Car: 2000 pathfinder, FG2 civic si
lately I've been getting some random start troubles and the car wont start unless i floor the gas resulting in a slight smell of gas in the cabin. it will have slight jumpy idles and I've already cleaned the MAF (which made the idles better). i bought a new battery last year and i add good fuel injection cleaner every oil change. does anyone have any ideas?
anthonyc
Car: 1998 Qx4
sorry that i dont have the answer, but the same thing happened to my altima this weekend. had to hold the pedal to the floor, to get it to start. after that, it started up fine.
SnowSurfLax
Car: 1999.5 Infiniti QX4
2006 Infiniti M35 Sport
May be a fuel pump issue? When's the last time you changed your fuel filter?
pathfinder_se_black
That is a good idea. should i get it done at the dealership? ive only done it on small cars like a celica.
02QX4ME
Car: 2002 QX4 4WD
I know mine is a bit different case but just want to bring it up here.
Two times after I charged my GPS with ignition turned to ACC or ON without starting the engine, for about an hour or so. Then I unplugged the GPS and started the engine. It didn't start. I took key out, then inserted and turned, it started normally as if nothing happend. I don't think the six month old battery got weak after one hour charging.
Other than that, zero problem over almost six years.
