Random Stalls
BoostedSRGuy18
Car: 1991 Nissan SR20DET 240sx silver
I got my car about 5 months ago, it runs great. Recently it will sometimes stall out when im at higher boost in a lower gear. It also does it sometimes when i start it up, it will just stall. I think it could be the fuel pump or maybe the injectors are clogged with some gunk. anyone who can elp please post back. it is really bugging me and i want to try and fix it without spending a lot of cash.
DuckyD
Car: 1995 240SX
Do you have an atmospheric blow-off valve (not recirculating)?That can cause issues with stalling.
plainzwalker
DuckyD wrote:Do you have an atmospheric blow-off valve (not recirculating)?That can cause issues with stalling.
I have this and only stall when i go from WOT or fast acceleration to no gas at all (coming to a stop usually).
I'd check the voltages at all the injectors to make sure they are working properly. I know on the KA they are supposed to be ~12v while running.
NY S13 SR
Check these low cost ideas:
Plugs - look for fouled black carbonTiming - set to 15 degrees with timing light - no guessing!Run some fuel injector cleanerfix any boost leakscheck MAF wiring for shorts
Good luck, _____________________Jeff HHeavy Throttle Performance Inchttp://www.heavythrottle.com
