mikebluesrt »
https://forums.nicoclub.com/mikebluesrt-u83533.html
Wed Mar 19, 2008 3:07 pm
i have a 90 and mine has similar problems. sometimes i go to start mine and it dies, then it will crank and crank and crank but it helps if i crank and hold the accelerator wide open. that made me think i had a fuel injector leaking. i have your other problem where randomly i'll pull up to a stop sign and it falls on its face when i start to take off. i have a brand new cap, rotor, plugs, wires, engine coolant sensor, oxygen sensor, cleaned the maf, cleaned the throttle body, replaced the fuel filter, cleaned the k&n but still the same problems. i haven't checked anything else since i'm buying a front clip this weekend but i am curious what everyone thinks it is
