DjPantsSpecR »
https://forums.nicoclub.com/djpantsspecr-u24575.html
Mon Sep 25, 2006 3:51 pm
i gotta disagree.
air bubbles in the coolant cause the temp to raise dramatically then drop quickly. Thats why coolant is being displaced as well. thats also why the coolant in ther overflow isnt hot. the air is the only thing thats overheting as it has a much lower specific heat constant, causing it to expand dramatically way before the coolant.
So, you just did this swap right? how long ago, and how much driving have you done without it overheating. how long are these trips as well.
now search around, because there are a billion threads on how to burp the coolant system, but my favorite is to get a burp funnel, turn the heat all they way to hot, and then run the car. this is the shortened version, but you'll find the real deal through searching.
on the other hand, if youve been driving it for a while, its a blown head gasket....
