ultimatuc »
https://forums.nicoclub.com/ultimatuc-u15850.html
Mon Jun 28, 2004 3:55 pm
ect= engine coolant temp sensor. It works as a negative temperature coefficiant thermistor. meaning, it has high resistance at low temps, and low w. high. the ecu senses the voltage left over after sending 5v through the resistor.
you may just want to scan for codes to see if this is your problem.
do you get any water leakage from the passenger side? this would suggest that your water pump may be going bad.otherwise, start w/ the cheap and easy stuff like the thermostat, radiator cap.......
