Random Miss
jlievens
Car: 1994 300zx
non turbo 5 speed convertible
Just put in a japan direct motor in my 1994 Nissan 300zx and switched all sensors out an have had no other issues starting up the car other than the idle alittle high adjusted that out an now idles around 850rpm but surges to 1100rpm every now an then but the main issue is a random miss
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
my pallet motor had a randome miss, it turned otu to be a cracked valve seat, if you measure good compression but still have loss on a leakdown test then it's likely a valve or seat issue
