Ramius83 »
https://forums.nicoclub.com/ramius83-u6643.html
Mon May 14, 2007 3:36 pm
Check your ignition coil plugs for any corrosion.
The one in question is located around your Upper Radiator hose on the passenger side of the engine bay. The plug is a long plug with wires side by side. It is very common of this plug to corrode over and cause a similar problem to what you are experiencing.
Another thing it could be is a leaky injector. Those injectors are prone to leak internally over time. When the leak, they dump too much fuel all the time, especially when cold, and will basically "flood" the cylinder and cause it not to fire. Then when the engine heats up, the problem may go away because the higher cylinder temps will ignite that fuel and make it appear that the engine is running fine.
Do those checks first.
