spuy767 wrote:Update: I was finally able to get some freeze frame data and the Short Term Fuel Trim on bank 2 seems low, at least, it's lower than bank 1. Wouldn't this lead to a rich condition? O2 sensor maybe?
Nissans STFT is called ALPHA readings with a Consult they should average around 100% +- 25% either way. A drop in one bank many indicate a vacuum leak or weak injector or fuel flow. Check the lower plenum and plugs on the drivers side. Although a ton of things can cause this those are easier to rule out.
Scoping the H02S2s would be a good indicator, also if you have access to live data check you CAL/LD at idle with no load (ac,lights,radio all off) it should be ~20% +-5%.
Many stupid things can cause a P0300 and the modern VQ can through one of those for a number of reasons.
GL
