S13xCrazy »
https://forums.nicoclub.com/s13xcrazy-u48564.html
Sat Apr 13, 2013 12:04 am
Alright guys, I'm pretty stumped here. I always try to avoid these topics, as I usually figure them out eventually but this one is really ticking me off!
Short story, bought the car with a damaged valve. Pulled it apart, got a new head and had it rebuilt, threw it together. no big deal. Previous owner was an idiot, I went through 100% of vac lines, fixed FPR setup, shoddy wiring, etc. etc. etc.
THE CAR:
Aermotive FPR Adjusted to proper psi, GT28, Recirc bov, freshly rebuilt head, Z32 maf, eprom tune, 440cc injectors. NO COLD START ACCESSORIES (ALL BLOCKED)
Compression is 150 across the board
Started it up and it was running pig rich. Black smoke.
OK, went ahead and went through the basics.
Checked timing, no problem, spot on. adjusted with a timing light as well.
Replaced plugs, o2 sensor sensor. The car was still running rich and had a dead miss now. After going through, I determined #4 injector was sticking. Got a good injector from a friend, put it in and it ran better but still had a slight miss and running pig rich still.
After this, i figured maybe MAF or another sticky injector. So instead of screwing with the stock tired stuff, I went ahead and got a Z32 maf, rebuilt 440cc injectors, and a tune my buddy used to run (worked great on his, same setup)
boost leaks - fixed a couple. No leaks
Vacuum leaks - Fixed a couple. Around 18hg/in now
TPS - Good and adjusted properly
O2 - brand new
Spark plugs - Brand new
MAF - Brand new
Injectors - Brand new
Coolant temp - Have swapped with others and same results
The car is still running very rich and has an intermittent miss. If you rev it up at all the miss goes away and it runs smooth, still smokes though. Going down the road I get a solid hesitation right before 3-5psi comes on.
Recap: Slight miss, black smoke, gas in oil, black spark plugs
Now, my best guess at this point is going to be old/tired coil packs, ignitor, or drop resistor. Any tips/ideas from the experts of CAs?
I understand you guys will want to blame the tune, but keep in mind this is 100% identical to what was happening with the stock tune and setup. Even tried a different stock ECU.
