thanks for the tip, i'll check it when i head homeBlackmobile wrote:your brightness adjustment knob might be loose. when you hit a bump it might wobble just enough to make the display go off
Mine did this before. I just manually adjusted the brightness to a different setting and back. Been fine since. I usually have it one step dimmer than full bright with the headlights on.downedzephyr wrote:thanks for the tip, i'll check it when i head homeBlackmobile wrote:your brightness adjustment knob might be loose. when you hit a bump it might wobble just enough to make the display go off
