Random Audio Drops
Discussion forum for body kits, repair, modifications, interior styling, Audio / Video and internal/external lighting.
exit9
Car: 2010 G37xS Prem/Nav
Lately, my 2010xS pre/nav has been experiencing random audio drops. This happens when listening to FM, XM, CD and ipod sources. The audio drops out (completely mute) for about 1.5 - 2 secs then comes back more on the right speakers then slowly balances to the lefts. Nothing crazy happens on the nav screen (as in flicker, fade, freezing, etc) when it occurs and it happens randomly so I'm not sure what could be causing it. Any ideas?
Thanks.
exit9
It happens even when I'm stopped. The strange thing is that when it starts it'll drop the audio twice within a 1 minute period then for the next 15-20 mins it's ok then it starts again. Switching the radio on/off doesn't change the behaviour.
joe603
Car: 2014 Durango R/T
I had to replace my Bose amp because the rear speakers were dead...take it to the dealer!
exit9
Update: Turned off all weather watch and warning msgs last Friday and so far no drops (knock on wood). I'm suspecting I may have been receiving blank audible warnings alerts which triggers the audio to cut out but nothing is being said.
exit9
Seems like turning off the XM warnings didn't fully cure my issue. The drops are coming back more frequent. Next step: dealer.
timmy0257
Car: 08 Infiniti G35 Journey 5AT
-R2C Intake
-interior LEDs w/ tag lights
-SBD grounding kit
-TBW engine cover
-Eibach Pro-kit
-JL Audio
Future Mods include GT-Spec strut bar & more.
hmm, do you have bluetooth? is it automatically pairing with your phone? if so, it could be an incompatibility with the phone and your BT system. Blackberrys receive data all the time and the BT system may recognize that as something that would normally override your stereo.
its a stretch, but i am sure it could happen.
exit9
timmy0257 wrote:hmm, do you have bluetooth? is it automatically pairing with your phone? if so, it could be an incompatibility with the phone and your BT system. Blackberrys receive data all the time and the BT system may recognize that as something that would normally override your stereo.
My phone is listed as fully compatible on the infiniti website but I can try turning off BT to see if that makes a difference. I've been experimenting for the past several days and the drops also occurs when using the nav so it's not just the limited to the ipod, fm, xm and cd sources.
timmy0257
-R2C Intake
-SBD grounding kit
-TBW engine cover
-Eibach Pro-kit
-JL Audio
i would say they just need to flash it or put a new unit in. good thing is that your covered under warr
exit9
I turned off BT this morning but it made no difference. I have an appointment with the dealer wednesday morning to look into it and also a rattle that's coming from the dash near the passenger A pillar. Hopefully, they won't tell me both are "normal" and nothing is wrong. :eek:
timmy0257
-R2C Intake
-SBD grounding kit
-TBW engine cover
-Eibach Pro-kit
-JL Audio
good luck with it. please update us.
exit9
update: went for a drive with tech. audio dropped randomly. new radio (they said "a/v unit" which may mean more than just the radio) ordered.
exit9
exit9 wrote:update: went for a drive with tech. audio dropped randomly. new radio (they said "a/v unit" which may mean more than just the radio) ordered.
Well it's been 45 days since they ordered a new radio and I haven't heard much from the dealer. Since this is my first Infiniti do parts take a long time to get in? Is 45 days acceptable so far or should I start following up with the service manager?
Thanks.
cameljockey
Car: '08 G35xS
it's your NAVigation, take off any destinations or whatever. I was bothered with this for a few days too. i thought my speaker was going bad.
exit9
cameljockey wrote:it's your NAVigation, take off any destinations or whatever. I was bothered with this for a few days too. i thought my speaker was going bad.
Tried that already and the tech tried other things but same problem. Followed up on the dealership. Seems like the radios are back-ordered from Clarion. I may have to deal with corporate and maybe they'll pull one off the assembly line.
Return to “G35 and G37 Interior, Exterior and Audio”
