USsil80 wrote:but from what i hear from my tuners is that once above about 85% duty cycle you get injector stag.. where inj. start to malfuntion and are open/closed when they aren't suppose to... what is your top power that you want to reach.. and fuel preassure is a bandaid but is can also kill you to if not carefull
Their experence and mine do not lign up. I won't say they are wrong but i just drove it down the track like that with zero knock and good Wideband readings.
I really like the EMS so far. I am definately looking forward to getting the launch controll set up. The wideband is SUPER easy you just run the supplied wiring harness and plug it straight into the back of the EMS and BAM you have real time non jumpy O2 readings.
It also IMMEDIATLEY started the first time even without an O2 sensor at all. On the map provided by aem. It starts hard when it's cold but that's from a lack of tuning. Remember AEM's offices are in Southern Cali
I'm running the SSAutochrome manny. I've had it on the car for about 4 months now with no issue.
I'm running 215's on the back. I have 17X7's front and rear
