PyR0NiAk »
https://forums.nicoclub.com/pyr0niak-u128099.html
Thu Jan 28, 2010 8:23 pm
My first guess would be fuel pump failure. This could've happened for 2 reasons. 1st, they use the gas to cool, so when your gas gets extremely low and they're running, they over heat. 2nd, you could've clogged the filter with the "gunk" at the bottom of the tank and, you guessed it, burnt it up. To remove your pump, pull the carpet in the trunk up and you'll see a circle with a bunch of bolts. Remove cover, unplug fuel pump, and then test fuel pump. See if it'll get power by touching it to a spare car battery. Red to positive and black to negative.
Edit: You can also test by unplugging your fuel line before the filter, and inserting it into a gas jug. Have someone turn on the key and then tell them to turn it off once you get fuel flow. If you get fuel flow, your next step will be to see if your filter is clogged. Put the filter on the line and then do the same thing. If you got fuel flow without the filter, but not WITH the filter, your filter is clogged. Try these and update me in this thread. If these don't show your problem, I have some other things you can do.
