Antjaw »
https://forums.nicoclub.com/antjaw-u5051.html
Thu May 29, 2003 7:33 pm
"Theoretically", If your son ran it dry then it could have picked up some sediment in the tank.. Happens all the time with older cars. The problem is that this sediment could have gotten clogged anywhere from the pickup before the fuel pump, all the way up to the injectors. My only suggestion is to start with the cheapest fix up to the most expensive or dificult. Fuel filter was definatly step one. You would assume that there was a good chance that the filter would catch anything big, so I would start back at the pump. The problem with any additive cleaners is that they are really only made to disolve petrol type of sediment.. If it was a peice of dirt, rust or coroded rubber, then an additive will have little or no effect.Hey, at least you know the problem lies in the fuel system somewhere...You could be startin from scratch.. Hope I helped and didnt bum you out.Good Luck!!
