Didderson wrote:2nd KAt- all that tastey tuning and they left the engine stock...
going to blow it up fast. Either do internals and enable safer fun w/ all the boost or at least clean the valve cover LOL...
I'm just gonna take a guess and say you DID NOT click on the link below the TWO pictures.....
KA24DETTBlockCustom CP pistons wpc treatedPauter Rods wpc treatedNew OEM crank wpc treated and shot pinnedCleavite main and rod bearings wpc treatedBlock has messured and sonic tested Arp main studsYellow munson high pressure oil pump wpc treatedHeadYellow munson race cylinder head p&pIN 307cfm EX 238cfm0.7mm oversize inconel valves IN0.5mm oversize inconel valves EX4 angle intake seatRadius exhaust seatMicro polished combustion chamberToga high temp valve sealSupertech dual valve springs with titanium retainerCrower V3 280 duration camsArp 11mm head studsCometic head gasketYellow munson custom full harmonically balanced crank pulleyYellow munson lightweight water pump pulley and alternator pulley with PS deleted Yellow munson custom twin turbo exhaust manifoldGT 3076R . 70ar twin scroll t3 divided housing x 2.Tial 44mm wastegate x 2 Yellow munson custom 3inch stainless steel exhaustYellow munson custom sheet metal intake manifold.90mm Q45 throttle bodyTwin drive injectors1600cc injectors and 550cc injectorsAeromotive pro series fuel pumpAeromotive pro series fuel pressure regulatorYellow munson custom fuel rai with -10in/outYellow munson 3.5 inch intercooler pipingDrivelineQuife 6 speed dog style transmissionCompetition custom ceramic twin plate clutchCarbon fiber driveshaftDriveshaft shop axlesTomei 2 way LSD with 4.36 final drivesYellow munson custom ladder bar set up for independent suspensionYellow munson tractions bar Yellow munson custom shocks and springs S2000 ignition coilCustom ignition coil bracketBlitz carbon fiber mirror gaugesBoost, egt, water, oil pressure, fuel pressure, custom exhaust pressure.Custom carbon fiber dashCarbon fiber consoleHKS EVC 6 with easy write softwareHKS knock amplifiers HKS twin power ignition HKS F con V pro 3.24 version HKS 3.5 bar map sensorHKS intake temp sensorsHKS v pro navigatorHKS mixture controllerAnd you wanted a painted Valve Cover!
