480sx »
https://forums.nicoclub.com/480sx-u50548.html
Tue Jun 23, 2009 4:58 pm
No, nissan would never put an undersized crank from the factory. Ever. You might have a crank that has had a regrind, therefore has oversized bearings. You might want to take it to a machine shop and double check. Expensive ish were talking here, its worth the ~100 bucks to check everything out professionally.
You need to go find a plastigauge dealer and buy some. Check all your clearances, also, check to make sure the plastigauge isnt compressed unevenly, indicating that one side is tighter than the other, or your cranks warped.
Also, i believe that the torque spec is 50 NM not foot pounds for the main girdle bolts. Remember, the whole Jap world and most Euro cars doesnt use foot pounds as a standard. The same is true with the nissan FSM.. They list ft pounds in some places but pretty much always go with NM as their first number.
