ran hot
girlscandrve2
okay my car ran hot... how do i tell if i blew the head gasket or cracked it
slipknotfan192
Car: S14 95 240sx SE
did you check if you have fluids in your Radiator
Welcome to Nico
slickster1013
How I found out i blew my head gasket, i looked and seen water spraying out. i put sealant in mine, it will work for awhile but not forever.
jdm_master_X
Car: 92 Nissan 180SX LHD!...LaWL
open ur radiator cap and see if it smells like death (coolant and oil mixture).
what makes you think you really blew the head gasket? ran it hard? because if that isnt the case then maybe its thermostat failure.
The Mic
Car: 3Z Wmb
girlscandrve2 wrote:okay my car ran hot... how do i tell if i blew the head gasket or cracked it
Symptoms of a blown head gasket are:
-reduced power-white or blue smoke out the tailpipe-oil in the coolant or coolant in the oil.
If you want to be thorough, you can perform a leakdown test.
Modified by The Mic at 5:52 PM 11/22/2005
SplitSecondConcepts240
Car: 93 240sx
have u flushed the radiator?
Chezedik
Car: 1991 Nissan 240sx
Try a compression test.
