modestmouse »
https://forums.nicoclub.com/modestmouse-u16390.html
Fri Aug 12, 2005 4:12 am
Hi guys, I've finished the wiring for my RB20 so I went ahead and ran a diagnostic check on the ECU and got a bunch of codes. I got 13, 14, 21, and 43, which are the Coolant Temp Circuit, Vehicle Speed Sensor Circuit, Ignition Circuit, and Throttle Position Circuit respectively.
I'm not worried about the first two b/c my speed sensor and coolant sensor to the ecu aren't hooked up. But besides that, everything should work. I will say though, that the motor is DEAD when it turns over. No signs of starting (besides the starter working). I'm not so sure what to do. Thanks for your help in advance!
