MainEvent212 »
https://forums.nicoclub.com/mainevent212-u5533.html
Sat Aug 14, 2004 6:24 pm
not true...the only reason any of you are getting your low power commuter cars to do "brake stands" if that's what you awnan call them, is because you have some ****ty tires. if you werent such cheap asses you wouldnt break loose like that and we wouldnt be having this conversation...
*moral of the story*240sxin- buy some decent tires stock size or maybe even plus width, falken azenis, kumho MX are both nice low buck tires to look into
do what i told you and you will run better times...soon as you stage, full brakes full throttle...soon as the light goes green, let off the brakes and cruise to the finish
EDIT:
here's an example...my car makes 210whp at 8psi, i'm runing 14 psi, so if we do some desktop dyno-ing it comes to about 230whp...i used to have 225/45/17 kumho ecsta supra 712 tires (crappy and worn) in the rear, on a flat clean surface, i could spin 1st gear till 25 mph...2nd gear and then shift till 3rd and actually spin half of 3rd gear...
i recently swapped new tires 245/45/17 kumho ecsta MX (dry tires and grip 10x better then the 712's) i now can launch hard, get moderate wheelspin, i hardly spin 2nd, 3rd is barely even a chirp on most clean surfaces...
what's the difference? i race my friend in his RSX-S to gauge anything i drive, just for fun. Why? he's very consistant..here's my 240 resultsOLD TIRES: less then 1 car length after traction
NEW TIRES: 3-4 cars by 90mph
