J-Owner »
https://forums.nicoclub.com/j-owner-u3840.html
Tue Jul 24, 2007 4:29 am
This sounds like an easy fix as I had the same problem and got them to fix it last week when my car was in the shop to have the driver's seat fixed.
We have gotten INCREDIBLE amounts of rain in the North Texas area so I noticed that mine had been dripping a bit from the driver's window at the top above the window controls.
The work order from the dealership stated that the left body weld or welt seal (he misspelled it I think) was slightly deformed so he removed the left body (again) weld or welt and used a heat gun to soften before reinstalling. However he did it it fixed the problem. It continues to rain here and no more dripping.
Mine is still under warranty so of course I didn't pay for it and not sure how much they would charge. The above explanation is in tech terms so if you tell the service department they should understand it I guess. My interpretation was that he took the rubber part off and melted it a bit to make it fit better and then put it back on.
Good luck. Hope this helps.
