Rain Sensing Wipers
LOOKATTHATSHINE
Car: 2012 Liquid Platinum Infiniti M37s
I just purchased my 2012 M37s last week and noticed a few days back when it was raining that my wipers had to be adjusted manually. Am I incorrect in thinking that the M37 has rain-sensing wipers? My car has the Premium & Sport packages only; no Tech package. FYI I did use the search feature before posting my question. :gapteeth:
wideopn11
Car: 2012 Infiniti M37x Moonlight White
Takeda CAI
Stillen exhaust w/ MeganRacing Y-pipe
SCALE coilovers 16K/10K F/R
Akebono BBK
Cusco strutbar
25mm spacers F/R
Uprev tune by seymore4
Yes is does have rain sensing wipers. From off/all the way up, 1 click down to auto-sensing mode then use the dial to adjust sensitivity.
LOOKATTHATSHINE
Thanks for the help. :)
Debonair
Car: 2011 Infiniti M56
I would like to add that they work great. We have had a few weeks of much needed rain here in Cali and the auto adjusting speed of the wipers work great as the rain density increases or decreases.
szh
Car: 2018 Tesla Model 3.
As I recall, the system also adjusts for the speed of the car ... wipers go faster when the car speeds up.
Z
Ilya
All true. I just wish it would detect the rain and turn the wiper on automatically, or turn it off once it stops raining instead of me having to do it.
#superlazy :rotflmao
SmoovC
Car: '06 Infiniti M45 Premium, Brakemotive, H-Techs, KYB's, USA-Spec PA15-INFI w/ BT streaming, Kuda cell mount, Magnaflow exhaust. (CAR SOLD)
Current: 2012 Infiniti M56S, Harbour Blue, 4 pc Aero Kit
Haha, I like the way you think IlyaKol!! :dblthumb:
LOOKATTHATSHINE
IlyaKol wrote:All true. I just wish it would detect the rain and turn the wiper on automatically, or turn it off once it stops raining instead of me having to do it.
Wait a second... i found the setting on the stalk and set it to auto... so even now if it starts raining the wipers won't start/stop by themselves? I thought that was the whole point of auto wipers lol.
Ilya
I don't know if they'll start, I just thought the auto setting was once you put it on that when it's already raining, they'll change speed depending on the speed of the car and amount of rain. Your point does make sense, if the windshield detects drops it should technically go from 0 speed (off) to whatever speed is needed to clean those drops off.
I shall change mine to auto as well and leave it and see what happens when it starts raining. I guess in theory it makes sense, lol.
wideopn11
Takeda CAI
Akebono BBK
Cusco strutbar
25mm spacers F/R
Yes, leaving the auto setting will allow your wipers to work when it starts raining without any further input from you.
SmoovC
I may be crazy, but I think I remember leaving the stalk in the auto position, and having the wipers do one swipe when I start the car. Anyone else experience this? It may have been before I had the battery replaced under warranty, so that could explain it.
Larz
Car: 2019 Q70-L RWD
Copied from the owner's manual (2009) but probably still accurate:
The rain-sensing auto wiper system can automatically turn on the wipers and adjust the wiper speed by using the rain sensor located on the upper part of the windshield.
To set the rain-sensing auto wiper system, push the wiper lever down to the [INT] position. The rain sensor sensitivity can be adjusted by turning the knob toward the front [HIGH], or toward the rear [LOW].
NOTE: While the lever is in the [INT] position, the wipers will sweep once each time the ignition is switched to the [ON] position - even if no rain is present.
CAUTION:
If the switch is left in the INT position, the wipers may operate unexpectedly when dirt, fingerprints, oil, film, or insects are stuck on or around the sensor. The wipers may also operate when exhaust gas or moisture affects the rain sensor.
SmoovC
Thanks Larz, I guess I should RTFM, once more for good measure. :chuckle:
Ilya
I can confirm this.
I had them on auto in to work today due to the nice coating of sleet/ice we got...and when I pulled into the parking garage they stopped and stayed off.
LOOKATTHATSHINE
IlyaKol wrote:I can confirm this.
Thanks for the confirmation. We have seen very little rain in Alabama over the past few weeks, particularly since I purchased the M.
M35austex
Car: 2012 M37S
2013 QX56
Agreed. Leave the stalk in auto and the sensor will determine when it's raining and turn them on/off accordingly. Sometimes, when starting the car, the wipers will do one swipe. I think this is from dust/dirt on my windshield. Never happens when I start in my garage or a public garage.
szh
I don't have the auto-position on my older 2003 M45 ... :crybaby
Z
TheMajesticKing
Car: '11 M56S Aero
Whats funny is that my old M56 had the tech package and my new one does not. The old one's rain-sensing wipers worked better than my current car. Even though they both have the feature it seems that the tech package allows it to work better. I'm not sure how and the dealer was no help of course.
Frog
Car: 2011 Infiniti M56 S
Don't Forget that if you have the windshield replaced. They should put a new rain sensing pad in with the window, that may explain why some people are having intermittent problems. The window could have been changed.
Vince2010
Where can you look to confirm if I have this feature on my 2012 M37X (4DR) or is this feature Standard equipment, also, is the dealer the only recommended glass place to replace it if the rain sensor feature exists. I live in th Dallas/Ft Worth Metroplex
Ilya
I believe it's labeled on the stalk itself...
Mjkkb2
Car: 2018 Infiniti QX60 AWD
2011 Infiniti M37S
2011 Nissan Quest
2001 Infiniti I30t(sold)
is the sensor part of the glass (windscreen)? Does it come with the windscreen, or can it be added on to it? Just want to be clear planning for a cracked windshield which happens to me every few years.
Mjkkb2
2011 Infiniti M37S
2011 Nissan Quest
Looks like a separate part, not cheap either $180.
stm37s
Car: '12 Chrysler 300 SRT8
'11 Infiniti M37 S
'06 Range Rover HSE (Wife's)
'12 Chevy Camaro LS (Wife's)
'95 Chevy Impala SS (sold)
'04 Chevy Impala SS (sold)
'12 Hyundai Veloster (Daughters)
wideopn11 wrote:Yes, leaving the auto setting will allow your wipers to work when it starts raining without any further input from you.
I leave mine in this setting as well for easy access, ha, ha
