Larz »
https://forums.nicoclub.com/larz-u216291.html
Tue Dec 30, 2014 11:10 am
First, Thank you for going to all the trouble you always go to just to help others. The mark of a true gentleman !
The sensor (as you know) is a one-piece unit that sits against the windscreen with a layer of what can only be described as a sticky, gooey layer of gel that forms a complete seal around the actual lens. According to the FSM, the lens emits an infrared beam that spreads through that gel and acts as a detector that somehow reacts to water on the outer surface of the windscreen. What a convoluted, complicated, waste of time and technology - just so we don't have to click the wiper bar down one notch?
I reckon your idea of blocking the sensor lens is a great one, however:
The only way to slide a piece of paper or any other barrier in front of the lens requires removal of the sensor from that gel and you are correct - if you pull the sensor away from that gel, you have to remove and replace a new gel layer before reinstalling the existing sensor. I found a source where I can buy two new gel layers (about $15 each). I could pull the sensor away from the existing gel, place a piece of something over the actual lens that blocks the infrared beam, install new gel, and reinstall the sensor. That might trick the BCM into thinking the sensor is fine, but there is no rain. Tha might allow me to use the intermittent wipers without them defaulting to ON. The only other option would be to have the dealer reprogram the BCM (if that's even possible) to ignore the sensor and act like the car does not have this worthless feature.
If blocking the sensor doesn't work, I reckon I will repeat the process with another new gel, reinstall the sensor without anything blocking the infrared beam, and just learn to live with the wipers going bonkers every few minutes and overriding the actual intermittent setting I choose.
