ezb57e »
https://forums.nicoclub.com/ezb57e-u238040.html
Sun Jul 06, 2014 9:52 am
With the engine idling listen to the injector with a stethoscope or a long screwdriver to your ear. It should be clicking. Compare the sound to other injectors. Don't be fooled by the sound of the other injectors clicking near it. If you are sure its not clicking, try wiggling the connector while listening. If it starts to click, the terminals are probably corroded. I cant remember off hand if that injector is an easy one to get to but you will need to get the connector off and have a look. Replacement connectors are available, but the injector terminals will need cleaning too. Scrape them VERY carefully (they can break) with a tiny jeweler's file. Once clean, check the resistance of the injector while you have it accessible. It should be around 15 ohms.
Of course, diagnosing cars over the internet is a crap shoot at best, but I hope this helps.
ezb
