NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Sat Apr 15, 2006 4:07 pm
Yes that is the fill plug but you can not simply pour fluid in there and its all good. You have to go through a bleading process to purge the air out. It requires you to put the top down, remove the inside trim panels, undo the rams from the stack, Disconnect one of the pink hoses from the pump,plug the port on the pump, place the pink hose in the fill hole of the resivor, opate the top to full up postion till all the air bubles stop coming out of the hose. Then do it again with the other pink hose. You will likely find a spraying leak once you bleed them. Thats how I found the hose leak on mine.
