Ragers summer to do list
Rager
Car: 1992 Nissan 300ZX 2+2
1999 Nissan Sentra
2004 Chevy Silverado
well this is my summer to do list. im getting a decent chunk of money on the first of august , so im going to try and do as much as I can and get the bang for my buck. my budget is is 5-7 hundred bucks. most of my attention will go to the interior but i have a few exterior things I want to do as well.
so here we go, stuff I want to fix inside,
I made an attempt about 4 years ago to fix this,
im going to try and find a leather shop to copy and make the shift boot, e brake boot and arm rest cover and have them keep it as close as possible to OEM . new OEM arm rest cover over 200 bucks
this
glove box that doesnt close anymore :squint:
this has pulled aprt over the years from the tt tops being removed :frown:
sun damage , im gonna try and find some type of leather dye or polish to clean it up.
looking for the tonnaue cover delete caps honad had on his in his recent update
found these on ebay
http://www.ebay.com/itm/90-96-NISSAN-30 ... 6rk%3D1%26
anyone know where I can buy them new?
as far as the exterior i want to get tints 250.00
and JDM tail lights. (i have a seperete fund for those)
I also currently have powertrix CO sitting in a box and a shaftmasters one piece aluminum DS also waiting to get installed.
WhiTTe Z
Car: '93 Z32 Twin Turbo 5spd
Ill sell you this newly upholstered leather CC lid for CHEAP
http://twinturbo.net/nissan/300zx/forum ... 32-22.html
As for the knobs and boots, save yourself the hassle and money of going to a professional and get them from http://www.interior-innovations.com/ I got mine from there and they look amazing.
WhiTTe Z
.... Just install them yourself, it is really simple, anyone can do it.
Also you say you have the powertrix coilovers all ready? That's great, the wise choice would be to spend your money not on the interior, but on the powertrix adjustable control arms which you will need if you plan on lowering the ride height with the coilovers. Unless you want your tires to wear out extremely fast that is due to rediculous negative camber.
Install the coilovers and control arms dude, what are you waiting for.
300ZXttZMAN
You could also check classifieds might be able to save some money.
2DLogic
Car: 1998 3000GT SL
1991 300ZX
Rager wrote:glove box that doesnt close anymore :squint:
Dunno if you saw or not, but I described what my problem turned out to be. Two small plastic pieces that keep tension on latch spring seem to have broken off.
Concept Z has the full assembly for sale here:http://www.conceptzperformance.com/Cart ... .251.55.41
I'm gonna try to find a Z in a salvage yard somewhere near by and try to pull it out of there before I spend $52 for a plastic housing however.
I'd also recommend Interior Innovations, I just recently picked up a nice Fairlady Z embossed leather wallet from them. Construction seems solid, shipping was prompt, and customer service was good. Only issue I had was not getting an order confirmation/invoice, but I contacted them and got a response quickly. I'll definitely be purchasing from them again.
Z-owned
Car: 93 N/A Z32
90 VW Corrado
01 mr2 spyder
2DLogic wrote:Dunno if you saw or not, but I described what my problem turned out to be. Two small plastic pieces that keep tension on latch spring seem to have broken off.
My car had this issue when I bought it and I just pulled the thing apart and epoxied the broken piece back together and it's held up fine for 4 years now.
Rager
1999 Nissan Sentra
so i pulled it apart! i think i have the same problem. it was a spring about a half inch long that was part of the actual "locking" mechinism . there was a very very small plastic piece that broke that held the spring.
so i guess glue at this point. im thinking gorilla glue other than it expands when dried but i can always clean up the hole the spring sits in.
Rager
1999 Nissan Sentra
update
:yesnod
so anyone have a right up to install these bad boys without breaking anything on my car?
300ZXttZMAN
NICE!!! Its self explanatory, take the interior panels off then some 10MM nuts hold the tails on.
After that you will just need to break the seal of your current tailights be careful not to get any of the tarrish black glue stuff on your car. (if you do though don't go crazy just grab some lighter fluid and put it on a rag and wipe, it will come right off - then rinse/wash the car)
Insert your new taillights with the new seals they should have came with.
Then put it all back together! :)
Z-owned
Car: 93 N/A Z32
90 VW Corrado
01 mr2 spyder
^ this though to expand a little a heat gun or leaving your car out in the sun will make the butyl much softer and easier to remove the old tails. If you need extra do to a bunch pulling off with the old tail lights you should be able to find it at your auto parts store. Also don't over tighten the nuts on the tail lights as you can pull the pressed in bolt right out of the tail lights
fabbio25
Car: 2014 Evo MR
1990 Z32 TT
Great information. I'll be doing this soon too.
Rager
1999 Nissan Sentra
installed
more updates to come
