see i checked the wires and all wires are connected to the harness right. but that wouldnt play any roll in the ocntrol over the radio. It still lights up you just lose all control over itxekushnr wrote:Did you hook up the illumination wire?
Well obviously something is, since you turn on the lights and lose control. Try unhooking the illumination wire and see what happens.urcaptnspeaking wrote:
This is what I was getting at. It is probably a white wire with an orange stripe. Snip it, tape it, test it out. It should be fine after this.dbranger wrote:Disconnect any orange wires... Solid orange or striped orange wires are illumination wires. Never disconnect those when hooking up an aftermarket radio. They aren't car specific and can short out certain features(hense your problem).
For the record, my deck (JVC GD-820) supports it, and its just to reduce the brightness when you turn the headlights on. Pretty cool feature.dbranger wrote:Yea I definetly meant to put never "connect" these wires
