Luvs2slide »
https://forums.nicoclub.com/luvs2slide-u48489.html
Wed Oct 11, 2006 7:12 pm
Car is a 93 240 Coupe. As the title states, No Dash lights (no illumination), HUD, odometer, tripometer do not work. The speedometer works. When I turn the key to accesorries, only the 4 lights to the right of the speedo works. All fuses are good. I checked through the forums and found all the topics concerning the Capacitor resoldering thread(s) and check of the TCM. Timing control module was good. A look at the HUD cluster checks good for a visual inspection of no burnt out paths. My greatest concern is that when I purchased the car I noticed the entire wiring harness for the radio was cut. I read a thread which talks about a Red/yellow wire and Red/blue wire that shouldnt be touched. Too late for that. Whats the fix for those wires? They are all cut flush with no wires protruding out. Do I just ground these? Or wrap with elec. tape? Any info is greatly appreciated.
