Radio
Vahagn23
Car: Nissan Versa S
Hi, do you guys know any good XM radios that arent portable or connect to the charging place of the car, so that I can replace the current system with that or something like that.
Ever Victorious
Car: '08 Kia Spectra 5
'73 AMC Hornet
All Satellite systems that integrate through the wiring (without the use of an XM transmitter) REQUIRE an SL.
Metra is working on a harness that allows a standard aftermarket XM tuner (such as Terk or Audiovox) to plug into the wiring for an SL and be controlled via the stereo's controls. It has not been released.
If you have an SL with Convenience, you can buy the Nissan OEM setup and it will work through your stereo/steering wheel controls.
Other than that, no. You're either going to have to replace your whole HU with a satellite compatible unit, then get the appropriate tuner, or put up with something that is powered by your DC outlet that uses either a wire to AUX or FM modulation.
Vahagn23
Car: Nissan Versa S
So if I dont have SL how much would it cost
