Radio switch
ddaltonttucker1
Can you take the radio from a Nissan versa and put it in a 2001 Nissan pathfinder
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
Depends on the speakers currently in the vehicle, really. If both systems have a Bose setup, things might work, I'm not sure - Bose stuff is proprietary. If the speakers are your typical 4-ohm speakers, all you should need to do is adapt the wiring harness to fit the Versa's head unit (assuming the head unit will fit in a single/double DIN slot), which isn't terribly difficult since the wiring diagram is available for the Versa's head unit.
