It's a different 7" not in the link provided. And yeah I'm sure I took all four screws out. When I'm trying to pull out the radio it just wiggles up and down a little bit but thats it. It's pissing the **** out of me...DJ_B_Easy wrote:Did you install the 7" that is in there now? Usually double dins are screw mounted to the stock trim piece. This is probably a stupid question but are you sure you unscrewed all 4 mounting screws in the OEM trim piece itself?
I more or less just want to see what headunit you have in there. If you can, pop off the bottom trim panel that hides the two bottom screws, pop out the HVAC vents, and snap one.xshinnyshinx wrote:I can't at the moment but I don't think I'm even able to get the pictures of the inside where I think it's making it stuck at
sorry, I meant the new one you just orderedxshinnyshinx wrote:It's a "Pyle" of s***.
http://www.amazon.com/Pyle-PLDN74BTI-Do ... +pldn74bti
I'll take some pics when I have the time.
