Kiven422 »
https://forums.nicoclub.com/kiven422-u74246.html
Sat Jan 17, 2009 1:10 pm
So some of you know my car broke down.. well its fixed now and I'm embarrassed to explain the solution. Just one of those things that require experience rather than education.
Anyways. I had taken the audio fuse out in effort to diagnose the car. Some bonehead put a 15AMP audio fuse when it should be a 20AMP. I did not know.
So I turned on the radio, it worked, but has not worked after that.
There are two audio fuses on the driver side. 20AMP & 10AMP... neither have blown, nor did the 15AMP while it was in there. However, the 1AMP fuse has blown for the power wire that goes from the HU to the CD changer.
Does that mean my radio has fried? Regardless of the CD Changer+CD fuse, the HU has always worked.
I disconnected my battery and will connect it again (1-hour) to see if that will help.
If someone has some ideas throw them out there please...
I really dig the stock HU.
