Radio retained power
buzzshipman
Car: 2002 Infiniti QX4
Hi, I just bought a 2002 QX4 for a second vehicle. I was wondering if anyone added retained power to the radio. The window works for 10 minutes but not the radio. Can I switch the power for the radio to what powers the windows so the radio keeps playing after I turn off the car. I normally have places to go and wait so having the radio on after I turn off the car would be great. I figured I can rewrite the radio somewhere to tap into the window power or what would I need to add to make this happen.
Thanks,
Kevin
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
The ignition signal into the AV Unit is what wakes it up. You don't want to change its power supply, just keep it awake. Snipping the ignition signal and re-routing it to a RAP power wire from the BCM should accomplish what you want.
buzzshipman
Yes I want to keep it on. Now I need to find out what wires they are so I can cut and tap into the other wire
VStar650CL
Technical Expert
Check the manuals here, they should have complete ones for an '02, including WD's. You can probably pick up a RAP wire most easily at the inside connector for the driver's door where the Main harness mates with the Door harness.
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
VStar650CL wrote:
Sun Jan 24, 2021 5:15 pm
Direct link to FSM:
https://www.nicoclub.com/service-manual ... %2Ffwd.pdf
