SteveTheTech »
https://forums.nicoclub.com/stevethetech-u103802.html
Fri May 29, 2009 4:21 pm
Hey there Bunky, Welcome to Nico.
Unfortunately there is no cheap remedy for this. Depending on the service history your dealer may be able to help you out. From my experience it seems like the audio switch assembly starts to fail more than likely takes the radio with it. I have had mixed results replacing one or the other than almost always end up putting the other part in.
If talking with the service consultant at your local dealer turns up with no result, then you can replace the radio with an aftermarket finisher plate.
Good Luck
