Radio problems
Pimpbott45
I've got a 94 Q45 and for some reason the radio won't play when the car is running. If I have the key in Acc the radio plays just fine. The second I start the car no sound. It still lights up and can switch inputs but no sound. Any thoughts?
Georgeb
It could be a problem with the power supply. If you send it to me I can diagnoses it for you and give you an estimate to fix it. If you decline it you just pay for shipping back you. Average range $125-$200 Might be less might exceed.
George
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Georgeb wrote:It could be a problem with the power supply. If you send it to me I can diagnoses it for you and give you an estimate to fix it. If you decline it you just pay for shipping back you. Average range $125-$200 Might be less might exceed.
George
So do you rehabilitate the Sony 10 CD cahngers also?
AlabamaDan
Car: 2015 Infiniti Q70
1998 Infiniti QX4
maxnix wrote:So do you rehabilitate the Sony 10 CD cahngers also?
And do you have any extras?
pdqwrx
Car: 1989 240 SX, 2002 WRX Wagon, 2003 FORD f150 4DR
Check around the car and see if anything else works when in Acc but not running. It sounds like a Ignition switch or relay contact issue to me.
Scott
Georgeb
We used to, but that unit is really old, OEM parts are hard to get.
