evildky »
https://forums.nicoclub.com/evildky-u13100.html
Wed Aug 30, 2006 5:03 pm
well...are your battery cables in good shape? do you have a good ground to the chassis and the engine? I'd make sure yout have a direct ground connection to the engine as well as the chassis ans if it's still giving you grief you might try making your own small grounding strap and screw it to one of the case screws on the body of the stereo and run it to a good chassis grouns, I had similar issue with an aftermarket stereo once, first I ran the harness ground to a chassis ground without success then got a small peice of wire with ring terminals at each end and grounded the chassis of the stereo to the chassis of the car
and welcome to nico!
