Radio Interchangeable
G8rDuc
Car: 96 Maxima/01 Pathfinder
Does anyone know if a 2005 Pathy Bose Radio will work with a 2001 Pathy Bose setup? Harnesses look the same except the 01 radio has a round black connector.
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
You can compare the wiring diagrams in the respective factory service manuals. Even if they are identical, the speakers may not be and their amps may not be compatible.
G8rDuc
Well the adapter harnesses are the same from what I've found. And the Maxima guys from the 90's are using them, so I think I might have found my answer. I'll let y'all know what happens.
