creophus »
https://forums.nicoclub.com/creophus-u4650.html
Tue Feb 18, 2003 12:54 pm
I agree with singlecamhonduhkilla,
Most likely you're shorting a wire somewhere. Do you blow the fuse in accordance with volume or simply a duration of time? Also, does it blow the fuse if your car isn't moving? Try replacing the fuse and simply turning on the radio at the lowest volume. See if it blows, then increase the volume, see if it blows, then drive the car and see if it blows...depending on when it blows, it will determine where the problem is.
I have installed many car stereos and the only time I've blown fuses is when wires touched. I've never installed in a 240 before, but I think it's very strange that there is something with a wiring harness connection needing to be grounded.
And whatever you do...DONT GET A BIGGER FUSE! Remember the fuse is blowing to PROTECT your radio.
