radio install
nitrojoe
Car: 1993 nissan hardbody 2wd
im trying to install an aftermarket radio in my 1993 hardbody. problem is i dont know which wires are the constant 12v power source, and which wire is the one that goes to the ignition switch. any help would be nice. thanks
StephenG
Car: 93 Nissan Hardbody 2wd KA24E 5spd
87 Nissan 200sx CA20E 5spd
IIRC, the red is ignition and the smaller gauge red with stripe is the 12v memory circuit. Mine may not have been stock though, it had been hacked up pretty bad by the previous owner. If all else fails, you can pull a wire from the fuse box for the ignition and pull a wire from your battery through the firewall for the 12v memory, just make sure to fuse that circuit for protection. Pretty much any auto parts store will have a small in-line fuse receptacle.
However, if you don't have to, you can buy an adapter from Scosche that will plug and play with no wiring for a few bucks. Their early nissan faceplate kit also includes a faceplate for our trucks that works quite well.
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Did you hack the truck wire harness or are the plugs still intact?
RT22
Car: 1991 nissan hardbody
search radio install and look for my name from a while back I put full wiring color code on here one day. Sorry but I do not have that sheet with colors handy but it is here under a radio post I responded to maybe 4-6 months or more ago.
nitrojoe
i finally got my radio wired up. i decided not to use an adapter to the stock harness i just wired it up myself as i wanted. a friend showed me this it tells what each wire in the harness does. made life easy. i think you can find this info for any nissan, or really most cars
http://www.the12volt.com/installbay/ste ... /1620.html
