Radio install = no interior lights??
jiansai05
I was installing my radio and when I hooked it back up the interior lights shut off and won't come back on, the automatic seat belts won't work, and the in dash clock won't work unless I turn the ignition over but not on. I checked all of the fuses in the kick panel and fuse box under the hood, haven't checked the one under the airbox yet.
Any help would be great Thanks.
locoluna825
Car: 90 240sx coupe
i DID THE SAME EXACT THING you blew a bunch of fuses. open the driver side kicker panel and check the fuses. I forget which ones are blown but you definitely blew some. when i played with my radio exact same thing happened to me, seat belt, clock, interior lights just like you described it.
scooz14
Car: 1989 240sx hatch
its the alt fuse in the engine bay pass side fuse box
100%
zachattack_5491
Car: Pignose S13 Redtop SR
scooz14 wrote:its the alt fuse in the engine bay pass side fuse box
100%
I swear to God if you're right about that... I've been rocking no dome light or cigarette lighter for like 3 months I must have checked those fuses like 10 times too. Although I will be pissed about not discovering it myself, I will love having my light back.
scooz14
its not a normal fuse though. i had to get one from the dealer.
locoluna825
Car: 90 240sx coupe
the one that went out in mine was a normal fuse
jpnissans13
Car: 1991 s13
lol same exact issue what i had!
scooz14
jpnissans13 wrote:lol same exact issue what i had!
what fixed it??
coltsd44
Car: 1990 240sx hatch - stock
how much was the fuse?and which one was it? i did the exact same thing.
plz and thank u!
scooz14
is a bigger not normal looking fuse in the fusebox by the battery.
rsagen
Car: 1989 240SX Coupe 5sp SOLD
1989 240SX Hatch auto SOLD
1990 240SX Coupe auto WRECKED
1990 240SX Hatch auto
1990 Jetta Turbodiesel 5sp FEILD BAGGED
1997 Jimmy 4WD
1985 Chev Wrangler
1994 F150 4X4
its the top left fuse. It is very hard to tell if it is blowen. Mine just blew and it only has a hairline gone. I couldnt find one anywhere is edmonton, so I wired in a 60amp fuse, it actually seams to work. I blew mine when I was boasting my car.
After mine blew, I started the car. Nothing worked. no dash, no radio, no tail lights, nothing. I touched the gas, and everything came alive. Everything seemed to work. I would be driving then I would go to hit the brake and everything would shut off, only the motor was running.
It was starting to piss me off before I put the 60 amp fuse in, so that is why I did it. And if I find the correct fuse someday I will install it, but this is good enough for me.
P_856
Car: s13
check the main interior fuse in the kick panel i think its a red one at the top right if not its the 75A alternator fuse in the fuse box in the engine bay its the big gray one http://i20.ebayimg.com/08/i/001/26/11/c686_1.JPG
vdub62387
you might have awire in the wrong spot
