Radio G35 coupe 2003
Discussion forum for body kits, repair, modifications, interior styling, Audio / Video and internal/external lighting.
O.v.n.Y
Car: Black G35 coupe 2003
Bonjour !
Est-ce qu'une console (radio) est 'plug fit' d'un G35 coupe 2003 vs 2006 ?
J'aimerais remplacer mon radio par celui equipé d'un GPS mais modele 2006 ?
Merci les boys !
O.v.n.Y
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Hello!
Is a console (radio) is 'plug fit' of a G35 cut 2003 vs 2006?
I would like to replace my radio one equipped with a GPS model but 2006?
Thank you the boys!
O.v.n.Y
Welcome! It is possible they may be compatible, but there may be more to adding GPS then swapping radios.
Bienvenue! Il est possible qu'ils soient compatibles, mais il peut y avoir plus d'ajouter GPS puis permutation radios.
Rogue One
2022 Honda Pilot SE
Ok, I did a little research. This will give you a better idea of what is needed to get a GPS radio from a 2006 to work in a 2003.
Parts list can be found here: http://www.infinitipartszone.com/Page_P ... nlPartList
O.v.n.Y
Ok thanks, cuz i have the complete console with GPS from a 2006.
I plan to replace the entire console.
Does the 'connector' are the same.
O.v.n.Y
Gilley
Generally, to get the navigation to work correctly in a car that did not have navigation will require some wire splicing. The wire harnesses are different between the navi cars and non-navi cars. It is not a plug and play situation. But it can be done.
audtatious
I highly suggest you dig through the FSM for wiring diagrams. If you get it figured out then please post the steps for others :)
http://www.nicoclub.com/archives/infini ... nuals.html
Return to “G35 and G37 Interior, Exterior and Audio”
