Radio doesnt work
solid
Hey i had the other post up buzzing and i you guys told me that it was interference in rcas, but now when i was just driving my whole entire sound system(deck, speakers, amps) just turned off. Anything that has to do with music wont work, its wont even turn on. Plus i took my muffler off and the pipe is pointed towards my wheel, will the heat coming out mess up the wheel in anyway? Thanks
specialkonrd
i dunnoa bout the exhaustbut check ur fusestheres a fuse for audio or electronics or somethign or other that should fix that ****
89sxRCR
Car: destroying self esteem
why the hell did you do that to ur exhaust? 99% sound problems are from wiring...check all fuses....grounds....basically everything to you find the problem.
solid
Well aunvoh runs with out a muffler and he laid down some good *** times, plus me and my friends hella **** with our cars. Thanks for the help guys.
specialkonrd
waitwhy do you need a radio if ur gonna run without a muffler? its not like ull be able to hear it loli know what your thinking, you have amps subs ect...so do i, and i could STILL heard my exhaust over all that when i knocked my pipe out of the cat (basically running open headers)
bp2ooo
there is a batt fuse that is a 7.5 Check that. If they blow it would knock out your radio. Im not sure about exhaust thing.
solid
thanx for the help.
