Radio delete panel removal 2009 Nissan Versa - how?
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
dorothy177
Car: Nissan Versa
Newbie question - the car came without a factory radio. I know how to wire a radio - but how do I remove the panel that covers where the radio goes? I cant seem to pop it off. Does it unbolt or something??
Thanks!!!
Glad to be a member!
steed77
Car: 09 Versa Fresh Powder Sedan 6speed
Easy... just did this 2 days ago for the radio install...
Remove this:top vent pannel ABOVE the radio. remove that 1st. lift slightly in the front and pull entire pannel toward driver.
then at the top there are 2 Philips screws holding the radio bezel down (remove them)then Pull/pop off toward driver again.
Remove the 2 plugs (air bag/ hazards)
then you are good to go.
Install your trim-kit and radio. Don't forget if you are using an aftermarket radio to add +12v(use the power antenna from deck) to the small wire on the antenna plug. You will have crap for reception if you leave that off.
barra
Car: Nissan Tiida S 1.8 t/a
Return to “Versa Technical Discussions”
