Hawairish »
https://forums.nicoclub.com/hawairish-u243869.html
Tue Jun 14, 2016 6:53 pm
So do you have the factory amps in place or not? And neither of the radios output sound with or without those amps?
If the amps are out, what are the ohm ratings of the speakers (might be stamped on the back of the magnet if, or you can ohm it directly...it'll read a little less than actual)?
If the amps are in, have you checked the voltage before and after the amps? Each amp gets a different ACC signal. Have you check the fuses? The battery test shouldn't work through the amp; you'd have to check it at the speaker, but it wouldn't really tell you much.
According to the wiring diagram, there's a pink wire that runs from the HU to both amps...since this is the only wire that does so, I'm inclined to think this is a turn-on lead. Is there a voltage on it when in ACC?
Since you indicated a few months ago that the front speakers wouldn't come on until later while driving, sounds like your front amp was on its way out. Perhaps they've both bit the bullet.
